TwinTurbo.NET: Nissan 300ZX forum - compression is low...
forced1(nyc)
on April 26, 2008 at 3:22 PM
1.150 psi
2.137 psi
3.135 psi(167 psi w/oil)
4.137 psi
5.145 psi
6.130 psi(145 psi w/oil)
compression is low... -
forced1(nyc)
15:22:47 04/26/08
Re: compression is low...
arthoes
17:51:34 04/26/08
txq45
18:37:22 04/26/08
Since the oil helped it is probably the rings (n/m)
na300zx (OH)
09:14:29 04/27/08
Should still run. Are you trying to find a no start issue? (n/m)
Spddracer
21:14:52 04/26/08
it starts. only after i gas it to death.
forced1(nyc)
22:16:49 04/26/08
It doesn't look emergent. I drove mine with 125-145 for
phillyz
09:12:59 04/27/08
15/50? i will give it a shot! (n/m)
forced1(nyc)
09:26:37 04/27/08
so was this when it was cold?
Ashman2k2
17:47:13 04/27/08
it was warm, and it was more than a tiny amountLOL (n/m)
forced1(nyc)
18:22:48 04/27/08
you should try doing it when the engine is cold...
Ashman2k2
01:35:03 04/28/08
